Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip. Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket. The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
  • Locate the six cables that are connected to the motherboard. The cable with the white strip is located underneath the cable with the orange strip.
  • Using the plastic opening tool on one side and your fingernail on the other, wedge each cable out of its socket.
  • The battery is now disconnected. If you want to remove the battery, follow the remaining steps in this guide. However, if you only wish to disconnect the battery to do other internal work, skip the remaining steps in this guide and continue on to other guides.
Insertar traducción aquí
