Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Inglés
Español
Paso 3
Remove the single 3 mm screw located on the top-right side of the Wi-Fi card using the Phillips #0 screwdriver. After replacing the Wi-Fi card, make sure that the cables are aligned. Otherwise, you could damage the metal connectors on the chip.
  • Remove the single 3 mm screw located on the top-right side of the Wi-Fi card using the Phillips #0 screwdriver.
  • After replacing the Wi-Fi card, make sure that the cables are aligned. Otherwise, you could damage the metal connectors on the chip.
Insertar traducción aquí
