Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck. Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
  • Carefully lift the 2 corners of the back panel close to the hinge upwards, releasing the whole panel.
  • Do not force the panel off. If it does not come off easily, try using a plastic spudger where it is stuck.
Insertar traducción aquí
