Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 3
Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off. Remove the L-shaped plastic hook. Once the L shaped hook has been removed the motor will easily fall out of place.
  • Once you have successfully unscrewed the five screws holding the cover on you should be able to take the cover off.
  • Remove the L-shaped plastic hook.
  • Once the L shaped hook has been removed the motor will easily fall out of place.
Insertar traducción aquí
