Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 5
Paso 5
To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver. Slide the old hard drive directly out. When reassembling, make sure the hard drive is securely in the case  before beginning.
  • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
  • Slide the old hard drive directly out.
  • When reassembling, make sure the hard drive is securely in the case before beginning.
Insertar traducción aquí
