Saltar al contenido principal
Inglés
Holandés
Traduciendo paso 13
Paso 13
iPad 4 Repairability Score: 2 out of 10 (10 is easiest to repair) The LCD is easy to remove once the front panel is gone.
  • iPad 4 Repairability Score: 2 out of 10 (10 is easiest to repair)
  • The LCD is easy to remove once the front panel is gone.
  • The battery is not soldered to the logic board, making the replacement process a tad less difficult.
  • Just like in the iPad 2 & 3, the front panel is glued to the rest of the device, greatly increasing the chances of cracking the glass when trying to remove it.
  • Gobs, gobs, and gobs of adhesive hold everything in place, including the prone-to-start-a-fire-if-punctured battery.
  • The LCD has foam sticky tape adhering it to the front panel, increasing chances of it being shattered during disassembly.
  • You can't access the front panel's connector until you remove the LCD.
Insertar traducción aquí
