Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise. The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
  • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
  • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
  • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
Insertar traducción aquí
