Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Paso 2
Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove the two 14 mm screws closest to the center of the hoverboard.
  • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove the two 15 mm screws located closest to the wheel.
Insertar traducción aquí
