Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 2
Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard. Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove the two 14 mm screws located closest to the center of the hoverboard.
  • Using a Phillips #1 screwdriver, remove the four 12 mm screws located in the middle of the panel.
  • Using a Phillips #1 screwdriver, remove two 15 mm screws located closest to the wheel.
Insertar traducción aquí
