Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Holandés
Paso 5
The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen. Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
  • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
Insertar traducción aquí
