Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 4
The display should now be entirely loose,  attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device. Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display. If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
  • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
  • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
Insertar traducción aquí
