Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Break the two warranty stickers by poking a screwdriver through them or peeling them off. Remove the following twenty screws by rotating the screwdriver counterclockwise: Eight 16.2mm Phillips #2 screws
  • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
  • Remove the following twenty screws by rotating the screwdriver counterclockwise:
  • Eight 16.2mm Phillips #2 screws
  • Eight 15mm Phillips #2 screws
  • Four 19.1mm Phillips #2 screws
  • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
  • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
Insertar traducción aquí
