Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 4
Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
  • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
  • Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
Insertar traducción aquí
