Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Traduciendo paso 2
Paso 2
Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel from the bottom.
