Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
  • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
  • Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
Insertar traducción aquí
