Saltar al contenido principal
Inglés
Español
Traduciendo paso 1
Paso 1
Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam. These four bolts should be torqued to 18 ft-lbs when putting the spark plug cover back on. These four bolts should be torqued to 18 ft-lbs when putting the spark plug cover back on.
  • Use the 1/2" socket to loosen and remove the four bolts and washers on the spark plug cover labeled 2.4L Twin Cam.
  • These four bolts should be torqued to 18 ft-lbs when putting the spark plug cover back on.
Insertar traducción aquí
