Saltar al contenido principal
Inglés
Español
Paso 12
Just like in the P20 Pro, the USB-C charging port is mounted to a large flex cable. This means if the charging port fails, you'll only have to replace the main cable—instead of a more expensive daughterboard, as in the Google Pixel 3 XL. Another similarity to the P-Series: no 3.5 mm headphone jack. USB-C headphones are included along with a 3.5 mm adapter.
  • Just like in the P20 Pro, the USB-C charging port is mounted to a large flex cable. This means if the charging port fails, you'll only have to replace the main cable—instead of a more expensive daughterboard, as in the Google Pixel 3 XL.
  • Another similarity to the P-Series: no 3.5 mm headphone jack. USB-C headphones are included along with a 3.5 mm adapter.
  • Yet, the Mate 20 and Mate 20 Lite both still have a headphone jack. Maybe Huawei isn't quite sure if USB-C alone is the future.
  • The other port, a SIM reader, is mounted to a small board, and planted near the coin-style vibration motor.
Al igual que en el P20 Pro, el puerto de carga USB-C está montado en un cable flexible grande. Esto significa que si el puerto de carga falla, tendrás que reemplazar el cable principal, en vez de una placa hija más costosa como en el Google Pixel 3 XL.
Otra similitud con la serie P: no tiene una entrada de auriculares de 3.5 mm. Se incluyen auriculares USB-C junto con un adaptador 3.5.
Sin embargo, el Mate 20 y el Mate 20 20 Lite todavía tiene una toma de auriculares. Quizá Huawei no está muy seguro si solo el USB-C es el futuro.
El otro puerto, el lector de SIM, está montado en una pequeña placa y plantado cerca del motor de vibración estilo moneda.
