Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 6 guías que incluyen este paso.
Inglés
Holandés
Traduciendo paso 1
Paso 1
Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board. To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
  • Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
  • To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
Insertar traducción aquí
