Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors. Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue. Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue.
cutting the new pads
  • Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors.
  • Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue.
Toma tu nueva pieza de almohadilla térmica y córtala del tamaño que necesitas utilizando un par de tijeras.
Algo de residuo podría cubrir un área más larga que la marca porque la almohadilla térmica estará apretada de forma plana. En esta caso, sigue el tamaño de la marca para la almohadilla nueva y no el tamaño del residuo.
