Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Inglés
Español
Paso 2
Remove the four 5mm screws on the top of the inside base piece using a Phillips #0 screwdriver. Remove the two 5mm screws on the bottom of the inside base piece which is near the strap with the same screwdriver. Remove the two 5mm screws on the bottom of the inside base piece which is near the strap with the same screwdriver.
  • Remove the four 5mm screws on the top of the inside base piece using a Phillips #0 screwdriver.
  • Remove the two 5mm screws on the bottom of the inside base piece which is near the strap with the same screwdriver.
Insertar traducción aquí
