Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Disconnect all the labeled connectors by opening their latches. Remove the flex cable that connects the logic board to the secondary control board. Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running to the connector.
Disconnect all the labeled cables
  • Disconnect all the labeled connectors by opening their latches.
  • Remove the flex cable that connects the logic board to the secondary control board.
  • Pull the small green connector out of its socket. Be careful when removing it, as it is possible to tear the tiny wires running to the connector.
  • Disconnect the two hidden connectors under the top connector labeled in pink.
  • Disconnect the third hidden connector.
Insertar traducción aquí
