Saltar al contenido principal
Inglés
Español
Paso 3
If the screw threads do not rise above the locking nut then STOP: The steering box is worn out, it is time to rebuild it, or replace it! Failure to do so could result in your steering system failing.
  • If the screw threads do not rise above the locking nut then STOP: The steering box is worn out, it is time to rebuild it, or replace it! Failure to do so could result in your steering system failing.
  • Loosen the Locking nut, so the set screw can be turned with a flat head screwdriver.
  • With the wheels straight and the steering wheel centered. Turn the lash adjustment screw clockwise until it stops, but don't force it any farther!
  • Making sure that the screw does not turn, carefully tighten the locking nut.
Insertar traducción aquí
