Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 3
Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone. Don't try to completely separate the screen; a small opening along the bottom edge is all you need. Insert an opening pick into the gap under the display on the lower edge of the iPhone.
  • Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
  • Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
  • Insert an opening pick into the gap under the display on the lower edge of the iPhone.
  • Skip the next two steps.
Sostén tu iPhone de forma segura y cierra el asa del iSclack para separar ligeramente la pantalla de la carcasa posterior del teléfono
No intentes separar completamente la pantalla; una pequeña apertura a lo largo del borde inferior es todo lo que necesitas.
Inserta una púa de apertura en el espacio debajo de la pantalla en el borde inferior en el iPhone.
Omite los dos pasos siguientes y continúa al paso siete.
[* black] Hold onto your iPhone securely and close the handle of the iSclack to slightly separate the screen from the rear case of the phone.
[* icon_caution] Don't try to completely separate the screen; a small opening along the bottom edge is all you need.
[* black] Insert an opening pick into the gap under the display on the lower edge of the iPhone.
[* black] '''Skip the next two steps and continue to step 7steps.'''
