Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Paso 11
Set the Force Touch sensor on top of the adhesive, back in the case. Be sure to properly orient it, with the connector in the lower left corner, facing up. Use a plastic opening tool to press it against the adhesive and make a tight seal. Use a plastic opening tool to press it against the adhesive and make a tight seal.
  • Set the Force Touch sensor on top of the adhesive, back in the case. Be sure to properly orient it, with the connector in the lower left corner, facing up.
  • Use a plastic opening tool to press it against the adhesive and make a tight seal.
Insertar traducción aquí
