Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando un prerrequisito para la guía que estabas viendo. Cualquier cambio que realices afectará la guía que incluye este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Use a Y000 driver to remove the single tri-point screw securing the Force Touch sensor connector cable. This screw is very small and strips easily. Keep your driver at the correct angle and push to apply pressure to the screw as you turn.
  • Use a Y000 driver to remove the single tri-point screw securing the Force Touch sensor connector cable.
  • This screw is very small and strips easily. Keep your driver at the correct angle and push to apply pressure to the screw as you turn.
Insertar traducción aquí
