Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 10
If you can see the top layer of your Force Touch sensor among the display adhesive, it means the two layers of the sensor separated and you're going to need to replace or repair it. The top layer of the sensor may be adhered to the back of the screen—push it down to separate it, and switch to our Force Touch Sensor guide from this point on. The top layer of the sensor may be adhered to the back of the screen—push it down to separate it, and switch to our Force Touch Sensor guide from this point on.
  • If you can see the top layer of your Force Touch sensor among the display adhesive, it means the two layers of the sensor separated and you're going to need to replace or repair it.
  • The top layer of the sensor may be adhered to the back of the screen—push it down to separate it, and switch to our Force Touch Sensor guide from this point on.
Si puedes ver la capa superior de tu sensor de Force Touch entre el adhesivo de pantalla, significa que las dos capas del sensor esta separadas y tendrás que reemplazarlas o repararlas.
La capa superior del sensor puede estar pegada al lado reverso de la pantalla—empujalo hacia abajo para separarlo y cambia hacia nuestra guia de Sensor de Force Touch a partir de aqui.
