Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 10
There are two cables connecting the screen to the inside of the watch, near the top left corner. Be careful when prying or you may damage these cables. Pry slightly up on the right side of the screen, to free it from any remaining adhesive. Pry up on the left to free it as well—but do not attempt to remove the screen as it is still held in place by two cables.
  • There are two cables connecting the screen to the inside of the watch, near the top left corner. Be careful when prying or you may damage these cables.
  • Pry slightly up on the right side of the screen, to free it from any remaining adhesive.
  • Pry up on the left to free it as well—but do not attempt to remove the screen as it is still held in place by two cables.
Hay dos cables conectando la pantalla al interior del reloj, cerca de la esquina superior izquierda. Ten cuidado cuando hagas palanca o puedes dañar estos cables.
Ligeramente haz palanca en el lado derecho de la pantalla, para liberarla de cualquier adhesivo restante.
Haz palanca en la izquierda para liberar lo también—pero no intentes de remover la pantalla ya que esta detenida en su lugar por dos cables.
