Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 6
The first photo is a close up of the wire harnesses.  Lots of wires here.  At first it looked difficult, but in fact GE did a nice job here.  Each wire harness is a difference size or shape, so it is fairly easy to get the wires back where they belong. Before I realized it wasn't going to be a mess re-assembling, I sketched a diagram of the colors and number of connectors, just in case.  But by the second time I repaired this, I didn't need to use it. The second and third photos are close ups of the bottom of the circuit board.  Important here is you need the screwdriver again.  All the wire harnesses can be removed by squeezing and pulling.  But the green ground wire is screwed in place.
Circuit board wires and wire harnesses
  • The first photo is a close up of the wire harnesses. Lots of wires here. At first it looked difficult, but in fact GE did a nice job here. Each wire harness is a difference size or shape, so it is fairly easy to get the wires back where they belong.
  • Before I realized it wasn't going to be a mess re-assembling, I sketched a diagram of the colors and number of connectors, just in case. But by the second time I repaired this, I didn't need to use it.
  • The second and third photos are close ups of the bottom of the circuit board. Important here is you need the screwdriver again. All the wire harnesses can be removed by squeezing and pulling. But the green ground wire is screwed in place.
Insertar traducción aquí
