Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Traduciendo paso 4
Paso 4
Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step. Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis. Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
Remove the display assembly
  • Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
  • Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
  • Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
  • Remove the display/screen assembly, being careful not to snag it on any cables.
Mantén la pantalla y el cuerpo principal del MacBook Pro bien sujetos. Cualquiera de las dos mitades puede caer inesperadamente durante este paso.
Empuja las dos mitades del MacBook Pro juntas para que los soportes de las bisagras puedan levantarse sin que queden huecos en el chasis.
Empuja el cuerpo principal del MacBook Pro lejos de ti mientras tiras de la pantalla hacia ti para separarlo.
Retira el ensamblaje de la pantalla, teniendo cuidado de no engancharlo en ningún cable.
[title] Remove the display assembly
[* icon_caution] Keep a firm grip on both the screen and main body of the MacBook Pro. Either half can fall unexpectedly during this step.
[* black] Push both halves of the MacBook Pro together so that the hinge brackets can be lifted clear of their recesses in the chassis.
[* black] Push the main body of the MacBook Pro away from you while pulling the screen toward you to separate it.
[* black] Remove the display/screen assembly, being careful not to snag it on any cables.
