Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a la guía que incluye este paso.
Inglés
Español
Paso 2
Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the  cover spring. Use a pair of tweezers to pull the cover spring of the display cable out of its recess. Repeat this step with the right cover spring of the display cable assembly.
Remove the display cable assembly
  • Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the cover spring.
  • Use a pair of tweezers to pull the cover spring of the display cable out of its recess.
  • Repeat this step with the right cover spring of the display cable assembly.
Toma el lado izquierdo del ensamblaje del cable de pantalla y jálalo hacia el extremo inferior del MacBook apartándolo de la bisagra del muelle.
Usa un par de pinzas para jalar y retirar la bisagra del muelle del cable de pantalla de su soporte.
Repite este paso con la bisagra derecha de muelle del ensamblaje de cable de pantalla.
[*title] Remove the display cable assembly
black] Grab the left side of the display cable assembly and pull it towards the bottom end of the MacBook and away from the spring hingecover spring.
[* black] Use a pair of tweezers to pull the cover spring hinge of the display cable out of its bracketrecess.
[* black] Repeat this step with the right cover spring hinge of the display cable assembly.
