Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 3 guías que incluyan este paso.
Inglés
Español
Paso 7
Carefully disconnect the three antenna coax cables by prying them straight up from the logic board. Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it. To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
  • Carefully disconnect the three antenna coax cables by prying them straight up from the logic board.
  • Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
  • To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
Usa un par de pinzar para desconectar los tres cables coaxiales de la placa madre.
[* black] Use a pair of tweezers toCarefully disconnect the three antenna coax cables by prying them '''straight up''' from the mainlogic board.
[* black] Slide your tweezers or the flat end of your spudger underneath each cable until it's near the socket, and then gently twist or pry up to disconnect it.
[* icon_reminder] To reconnect each cable, align the connector directly over its socket, and then press down so it snaps into place.
