Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 8 guías que incluyan este paso.
Inglés
Español
Traduciendo paso 7
Paso 7
Use a spudger to gently lift the battery power connector, disconnecting the battery. Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Disconnect the battery
  • Use a spudger to gently lift the battery power connector, disconnecting the battery.
  • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
Usa un spudger para levantar con cuidado el conector de alimentación de la batería desconectando la batería.
Levanta el conector de forma quede separado de su zócalo. Si hace contacto accidentalmente durante la reparación, podría dañar tu MacBook Pro.
[title] Disconnect the battery
[* black] Use a spudger to gently lift the battery power connector, disconnecting the battery.
[* black] Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
