Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 6
Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case. Pull first at one corner, then the other. Pull to the side—not up.
  • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
  • Pull first at one corner, then the other.
  • Pull to the side—not up.
  • This can require a lot of force.
Tira de la carcasa inferior firmemente hacia la parte frontal del MacBook (lejos del área de la bisagra) para separar el último de los clips que aseguran la carcasa inferior.
Puede ayudar tirar primero en una esquina, luego en la otra. En caso de que no puedas separar el clip de la caja inferior, puedes aplicar una ventosa en el lado de la esquina con el clip y usarlo con cuidado como tirador.
[* black] Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
[* icon_note] It may help to pullblack] Pull first at one corner, then the other. In case you aren't able
[* icon_caution] Pull
to separate the clip from the lower case youside—not up.
[* icon_note] This
can apply a suction cup next to the corner with the clip and carefully use it asrequire a pulling handlelot of force.
[* icon_note] This
