Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 10 guías que incluyan este paso.
Inglés
Español
Paso 3
Insert one corner of an opening pick into the space between the lower case and the chassis. Slide the opening pick around the nearest corner and halfway up the side of the case. This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
Separate the clips
  • Insert one corner of an opening pick into the space between the lower case and the chassis.
  • Slide the opening pick around the nearest corner and halfway up the side of the case.
  • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
Inserta una esquina de una púa de apertura en el espacio entre la caja inferior y el chasis.
Desliza la púa de apertura alrededor de la esquina más cercana y hasta la mitad del lado del estuche.
Esto libera el primero de los clips ocultos que aseguran la carcasa inferior al chasis. Debes sentir y escuchar el clip liberarse.
[title] Separate the clips
[* black] Insert one corner of an opening pick into the space between the lower case and the chassis.
[* black] Slide the opening pick around the nearest corner and halfway up the side of the case.
[* icon_note] This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
