Saltar al contenido principal
Inglés
Holandés
Paso 5
Now the NFC module is free.  There's some tape on the back of the module; you can peel it off with tweezers. You can see there are two solder bumps under here.  These are the connections to the NFC antenna. If you use alcohol or some other solvent to help clean up, use it very sparingly.  We don't want to mess up the Light Sensor.
Successful donation
  • Now the NFC module is free. There's some tape on the back of the module; you can peel it off with tweezers.
  • You can see there are two solder bumps under here. These are the connections to the NFC antenna.
  • If you use alcohol or some other solvent to help clean up, use it very sparingly. We don't want to mess up the Light Sensor.
Insertar traducción aquí
