Saltar al contenido principal
Inglés
Español
Traduciendo paso 4
Paso 4
With pry bar go a around the outer edge of the trim of the panel where it meets the door and pry out words continue doing this all the way around the door until it pops almost completely off Now where the handle was look inside you'll see his screw Phillips head that needs to be loosened and the panel will come off (pic2) Now where the handle was look inside you'll see his screw Phillips head that needs to be loosened and the panel will come off (pic2)
Panel off
  • With pry bar go a around the outer edge of the trim of the panel where it meets the door and pry out words continue doing this all the way around the door until it pops almost completely off
  • Now where the handle was look inside you'll see his screw Phillips head that needs to be loosened and the panel will come off (pic2)
Insertar traducción aquí
