Saltar al contenido principal
Inglés
Español
Paso 20
Remove the fuel lines from the fuel filter assembly. There are three lines - you are only removing two of them.
  • Remove the fuel lines from the fuel filter assembly.
  • There are three lines - you are only removing two of them.
  • Remove the two lines that have plastic connectors on the ends.
  • Release the connections by pressing in on the plastic tabs similar to the vent hose connection we did in a previous step.
  • The large fuel line has two tabs (one on each side) - I was able to squeeze this with my fingers to remove.
  • The small fuel line has one tab - I used a screw driver to push that tab in.
  • After you push the tab(s) in, pull the fuel line off.
  • The third hose on the fuel filter assembly is fastened by a metal clip - do not remove this one. We'll remove the other end of this hose in the next step.
Insertar traducción aquí
