Saltar al contenido principal
Inglés
Español
Paso 19
Pull the fuel filter assembly out of the gas tank. There are many connections on the assembly that will restrict you from pulling it out.
  • Pull the fuel filter assembly out of the gas tank.
  • There are many connections on the assembly that will restrict you from pulling it out.
  • The first thing you'll run into are the electrical connections.
  • Pull these off and set them aside. They are going to fall into the tank. You may be able to rest them on something - or you may have to fish them out of the tank later if you lose track of them.
  • Notice how these connectors are installed so you can reinstall them later. One is polarized (meaning it can only attach in one direction) - the other is not. I suspect that the non-polarized connector can go on either way without harm - but I wouldn't chance it.
  • Pay attention to the direction it is when you take it off so you can reinstall it the same way later.
Insertar traducción aquí
