Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 15
Go back to the fuel tank access ports. Remove the electrical connector for the fuel pump.
  • Go back to the fuel tank access ports.
  • Remove the electrical connector for the fuel pump.
  • Use a large flat blade screw driver to insert into the tab. Gently push the top of the screw driver toward the wires.
  • Pull up on the connector. If yours is difficult to remove, you can get some extra leverage from a 90° screwdriver as shown.
  • Be sure to release the latch (using the large flat blade screwdriver) before prying up with the 90° screwdriver.
Insertar traducción aquí
