Saltar al contenido principal
Inglés
Español
Paso 2
Using a T30 Torx driver, remove the bolt that secures the clip in place. Remove the clip.  Do this by rotating the clip toward the front of the car - don't worry if you can't get it completely out.  You can remove the clip after the left seatback is removed.  Just be sure you can get the left seatback loose. Remove the clip.  Do this by rotating the clip toward the front of the car - don't worry if you can't get it completely out.  You can remove the clip after the left seatback is removed.  Just be sure you can get the left seatback loose.
  • Using a T30 Torx driver, remove the bolt that secures the clip in place.
  • Remove the clip. Do this by rotating the clip toward the front of the car - don't worry if you can't get it completely out. You can remove the clip after the left seatback is removed. Just be sure you can get the left seatback loose.
Insertar traducción aquí
