Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 11
Look here!  There's gas floating around on top of the driver's side.  It also looks "clean" and shiny (compared to the passenger side). Upon closer inspection (and a tip from Crazyhippy) the leak is at the top of the dome.  Zooming in shows about a 1/8" crack seen in the pictures as a discoloration at the top of the dome. When the fuel pump is on, the gas is flowing.  Even after the pump stops, the gas keeps coming out (as I imagine the system is still under pressure).
  • Look here! There's gas floating around on top of the driver's side. It also looks "clean" and shiny (compared to the passenger side).
  • Upon closer inspection (and a tip from Crazyhippy) the leak is at the top of the dome. Zooming in shows about a 1/8" crack seen in the pictures as a discoloration at the top of the dome.
  • When the fuel pump is on, the gas is flowing. Even after the pump stops, the gas keeps coming out (as I imagine the system is still under pressure).
  • VW part number for this assembly is 7L0 919 679. World Impex has a VDO equivalent (the original is made by VDO as well) for under $100. See here.
Insertar traducción aquí
