Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 3
Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly. Unscrew the second screw located approximately 6 inches below the first. Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
  • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
  • Unscrew the second screw located approximately 6 inches below the first.
  • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
  • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
Insertar traducción aquí
