Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 2 guías que incluyen este paso.
Inglés
Español
Paso 4
Approach this step with the process of unbuttoning a shirt in mind. Be careful if the rubber gasket is dry-rotted.  Use vaseline to re-moisturize if necessary.  Manipulating dry-rotted rubber will result in tearing.
  • Approach this step with the process of unbuttoning a shirt in mind.
  • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
  • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
Insertar traducción aquí
