Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Inglés
Español
Paso 2
Use the point of a spudger to pry the speaker up. The speaker is adhered with light adhesive inside the speaker well, so a bit of force is required. Use your fingers or a pair of tweezers to remove the right speaker.
  • Use the point of a spudger to pry the speaker up.
  • The speaker is adhered with light adhesive inside the speaker well, so a bit of force is required.
  • Use your fingers or a pair of tweezers to remove the right speaker.
Levanta suavemente el altavoz por sus cables y tira de él en un ángulo de 45 grados para retirarlo.
[* black] Gently liftUse the loudspeaker up by its wires and pull out atpoint of a 45 degree anglespudger to removepry the speaker up.
[* icon_note] The speaker is adhered with light adhesive inside the speaker well, so a bit of force is required.
[* black] Use your fingers or a pair of tweezers to remove the right speaker
