Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 4 guías que incluyen este paso.
Inglés
Español
Paso 9
Carefully pry the cover away from the phone. This may take a lot of force if the adhesive in the middle is still attached. As you lift the cover, you may need to use an opening pick to slice through any remaining adhesive. To reinstall the back cover:
  • Carefully pry the cover away from the phone.
  • This may take a lot of force if the adhesive in the middle is still attached. As you lift the cover, you may need to use an opening pick to slice through any remaining adhesive.
  • To reinstall the back cover:
  • First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
  • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
  • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
  • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
  • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
Con cuidado haz palanca en la tapa y apártala del teléfono.
Esto puede tomar mucha fuerza si el adhesivo en el medio todavía está adherido. A medida que levantas la tapa, es posible que tengas que usar una púa de apertura para cortar el adhesivo restante.
Para volver a instalar la tapa trasera:
Primero usa pinzas y un spudger para pelar y raspar el adhesivo restante tanto de la tapa posterior como del chasis del teléfono.
Luego limpia las áreas de adhesión con alcohol isopropílico de alta concentración (al menos 90%) y un paño que no suelte pelusa. Pasa solo en una dirección, no hacia adelante y hacia atrás. Esto ayudará a preparar la superficie para el nuevo adhesivo.
El adhesivo de reemplazo viene en una hoja precortada que coincide de forma exacta con los contornos de la tapa posterior. Si no está disponible, puedes utilizar una cinta de doble cara de alta adherencia, como Tesa 61395. Antes de instalar el adhesivo precortado en la tapa posterior, retira el inserto de metal. Instala el adhesivo, luego reemplaza el inserto.
Después de instalar la tapa posterior, aplica una presión fuerte y constante en el teléfono durante varios minutos para ayudar a que el adhesivo forme una buena unión.
Si lo deseas, puedes volver a instalar la tapa posterior sin reemplazar el adhesivo. Retira cualquier trozo grande de adhesivo que pueda evitar que la tapa posterior se asiente al ras. Después de la instalación, calienta la tapa posterior y aplica presión para asegurarla.
