Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 11 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 3
Paso 3
Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it. You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste. Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
  • Use a spudger or your fingers to lift the heatsink up and off the motherboard to remove it.
  • You may feel a bit of resistance. This is normal, since the heat sink is slightly bonded to the CPU with thermal paste.
  • Clean off the old thermal paste from the heat sink and CPU using high-concentration (90% or higher) isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the CPU before reassembly.
Usa una spudger o tus dedos para levantar el disipador arriba y fuera de la placa madre para removerlo
Puede que sientas un poco de resistencia. Esto es normal debido a que el disipador esta pegado ligeramente al CPU con pasta termal
Limpia toda la pasta térmica del disipador y del CPU utilizando alcohol isopropilico de concentración alta (90% o major) y una tela de microfibra. Aplica la nueva pasta termal al CPU antes del re-ensamble
