Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 7 guías que incluyan este paso.
Inglés
Español
Paso 6
Insert an opening pick under the display and carefully separate the Force Touch gasket from the display. iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged. Otherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
  • Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
  • iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged.
  • Otherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
  • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
  • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
Inserta una púa de apertura debajo de la pantalla y separa cuidadosamente la junta de Force Touch de la pantalla.
Asegúrate de encontrarte debajo de la pantalla. Si la junta de Force Touch se separa al levantar la pantalla, o si separas las capas de la junta, también tendrás que reemplazar la junta de Force Touch en sí misma.
Desliza la púa alrededor de la pantalla para separar el adhesivo entre el Force Touch y la pantalla.
No insertes la púa de apertura más de 1/16 de una pulgada (~2 mm).
[* black] Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
[* icon_note] iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged.
icon_caution] Make sure you get right underneathOtherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to [guide|113009|replacereplace the Force Touch gasket|new_window=true]gasket itself.
[* black] Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
[* icon_caution] Don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
