Saltar al contenido principal
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 7 guías que incluyen este paso.
Inglés
Español
Paso 5
Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap. Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
  • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
  • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
  • Don't try to fully open or detach the display yet.
Una vez que se ha creado un pequeño espacio con la hoja curvada, retira la hoja e inserta el borde mas delgado de una herramienta de apertura en el hueco.
Empuja la herramienta de apertura en el hueco. Usando tu pulgar como un pivote para levantar la pantalla abierta un poco más lejos.
No intentes abrir la pantalla completamente. La junta del Force Touch podría pegarse a la pantalla o la caja y se romperá si es forzada.
[* black] Once you've opened a small gap has been created with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
[* black] Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
[* icon_caution] Do notDon't try to fully open or detach the display all the way. The Force Touch gasket may stick to either the display or body, and will tear if forcedyet.
