Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 2 guías que incluyan este paso.
Inglés
Español
Paso 19
Disconnect the two speaker connectors by sliding the flat end of your spudger underneath each cable near its connector. Gently twist or pry up to disconnect both speakers. Gently twist or pry up to disconnect both speakers.
  • Disconnect the two speaker connectors by sliding the flat end of your spudger underneath each cable near its connector.
  • Gently twist or pry up to disconnect both speakers.
Desconecta los dos conectores de altavoces deslizando el extremo plano de tu spudger por debajo de cada cable cerca de su conector.
Gira o levanta suavemente para desconectar ambos altavoces.
