Saltar al contenido principal
Aviso: Estás editando un prerrequisito para la guía que estabas viendo hace poco. Cualquier cambio que realices afectará todas las 5 guías que incluyan este paso.
Inglés
Español
Paso 6
Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display. Gently feed the trackpad's ribbon cable through its slot in the chassis. Carefully note the correct slot for the trackpad cable during reassembly—it goes through the narrow slot alongside the battery, not the bigger slot near the MacBook Pro's front edge.
  • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
  • Gently feed the trackpad's ribbon cable through its slot in the chassis.
  • Carefully note the correct slot for the trackpad cable during reassembly—it goes through the narrow slot alongside the battery, not the bigger slot near the MacBook Pro's front edge.
Abre la pantalla ligeramente, pero mantén el MacBook al revés. El conjunto del trackpad debe separarse y quedar plano en la pantalla.
Pasa suavemente el cable plano del trackpad a través de su ranura en el chasis.
Observa con cuidado la ranura correcta para el cable del trackpad durante el reensamblaje: atraviesa la ranura estrecha junto a la batería, no la ranura más grande cerca del borde frontal de la MacBook Pro.
